It is currently Mon May 25, 2026 8:36 am
PostPosted: Sat Jun 21, 2008 10:51 pm
Hello,
The ratios a the stock luv trans are:
1 3.51:1
2 2.18:1
3 1.42:1
4 1.00:1
rev 3.83:1
MUA5:
1st: 3.767
2nd: 2.248
3rd: 1.404
4th: 1.000
5th: 0.809
Rev: 3.875
xfer: 2.283
What is the ratio for the xfer case on the stock luv 4x4?
I might be able to start off in 2nd gear with the MUA-5 lol..
PostPosted: Thu Jul 10, 2008 7:36 pm
The more I think about this swap the more I want to do it. I just need a job! The ratio differential is only .2 for 4th to 5th, whereas it can be much wider between other gears, I think for flat roads 5th gear will give me a marked improvement in gas mileage and engine wear!
