It is currently Mon May 25, 2026 2:31 pm
 Post subject: hot water choke
PostPosted: Fri Jun 13, 2008 6:05 am
I recently bought a holley 5210 to put on my '79 4x4. It came with a hot water choke. I was thinking about hooking it up. Any thoughts on that? I am unsure of how to route the waterlines. Do you think I could route the one coming from the front of the block to the choke and then out from the choke to the connection on the underside of the intake?
 Post subject: Re: hot water choke
PostPosted: Fri Jun 13, 2008 10:46 pm
Australian LUV Guru
Save yourself the hassle of routeing water lines and potential leaks/ corrosion, fit a mechanical/ hand operated choke.
1980 4x4 KBD40 ISUZU/Chev Luv
