It is currently Mon May 25, 2026 10:01 am
 Post subject: S10 9" ford in a Luv
PostPosted: Mon Jun 09, 2008 10:45 am
If a s10 rear end is supposed to be a direct fit into a Luv, it would seem if 9" rear end is narrowed to fit a s10 stock frame should work great. Yes?
I think I may be able to lay my hands on one of these...But no sense buying it if it will have to be narrowed anyway.
 Post subject: Re: S10 9" ford in a Luv
PostPosted: Mon Jun 09, 2008 12:10 pm
If its stock width, its going to be a little wide, your tires will stick out.Other than that it will fit fine.
PostPosted: Mon Jun 09, 2008 12:38 pm
Rims from a later or a different model with a different offset will fix that.
Im thinking 8"+ wide. :wink:
Bob.
PostPosted: Mon Jun 09, 2008 3:29 pm
thats why god made offset rims :D
PostPosted: Mon Jun 09, 2008 6:24 pm
My luv has a stock width Camaro 10 bolt rearend with Late model Camaro Wheels, they sit a little outside the fenders. Not too bad. I guess A different offset might be the way to go. My current engine is alright with the 10 bolt. I may as well just keep it that way
PostPosted: Tue Jun 10, 2008 8:05 am
papa where might this rear end be?
PostPosted: Tue Jun 10, 2008 8:33 am
It was gone before I got a call back about it. :(
