It is currently Mon May 25, 2026 10:50 am
 Post subject: Stock rear measurements
PostPosted: Thu May 15, 2008 1:56 pm
Do you guys know what the measurements are for the stock rear in a 75 chevy luv. or somwhere where I can see them. Drum to drum flange to flange, perch to perch.
thank you.
I'm doing research at work and I want to find something that will drop right in with 2.73 gears
-64dartsb
PostPosted: Thu May 15, 2008 3:02 pm
bump
PostPosted: Fri May 16, 2008 12:30 am
they say s-10 rear end pretty much drops right in
PostPosted: Fri May 16, 2008 1:32 pm
it is a drop in . Did the S10 swap about 2 weeks ago and it fits really nice. I used a 2000 S10 v6 rearend
PostPosted: Fri May 16, 2008 8:36 pm
hey bama....does the 2000 rearend have better gearing than the recomended '82-92 rearends?
PostPosted: Sat May 17, 2008 8:47 am
I think mine was 52 " I run 4 "or 4.25 " backspace . If i did it again I would change it to fit the more popular 4.5 or 5.5 back space and would run Chevy car bolt pattern .
PostPosted: Mon May 19, 2008 9:31 am
Sorry it took so long to reply busy weeekend.
I used a 2000 V6 rear end because it is a 28 spline with a 3.42 open diff. Where the earlier are 26 spline and usually a numerically higher rear gear (4.10 , etc). I bought a posi unit off ebay rebuilt for 225.00 free shipping http://cgi.ebay.com/ebaymotors/_Car-Truck-Parts-Accessories__GM-7-5-7-625-10-BOLT-EATON-GOV-LOC-POSI-28-SPLINE-G80_W0QQitemZ190222342751QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQadiZ2865QQcmdZViewItem?hash=item190222342751& And he ships fast.
I got my rear end out of a junkyard for 100.00 and got Mooser axles for 235.00 a set.( I ordered a set of 2000 S10 axles with the luv bolt pattern 6 X 5.5)
But here are the codes for S10 rears. They are listed in the glove box.
rear axle ratio RPO
GU4=3.08
GU5=3.23
GU6=3.42
GT4=3.73
GT5=4.10
HC4=4.56
G80 - locking differential
but my understanding is that a 2nd gen V6/Auto will have a 3.42 gear but I would verify by the RPO code in the glove box.
PostPosted: Mon May 19, 2008 8:58 pm
thanks bama that helps w/decideing what gearing to go w/and how to tell what i'm getting from the boneyard
PostPosted: Tue May 20, 2008 5:19 am
you are welcome :P
PostPosted: Wed May 21, 2008 2:54 pm
the measurement from backing plate to backing plate is 48 and 52 outside drum to drum.
hotrod i have the 4.5 bs prostar 8" rim and with a 29.5/10.5 tire i have to use 1/4 inch spacers, now i have the hoosiers 29/9.0 and i don't need the spacers but i lost alot of traction on the 9' tire.
Users browsing this forum: Bing [Bot] and 38 guests
