It is currently Mon May 25, 2026 4:33 am
PostPosted: Tue Mar 11, 2008 1:19 pm
Ok so I did the Offy webber and pacesetter upgrades but I have a few questions to ask before I can finish I got the thing running but need to take care of few things.
Has anyone had troubles with there pacesetter header. I cant get the cylinder closest to the fire wall to seal up. IT sounds horiable. Do I need to double the gasket or jsut start somewhere else when im tightening it.
Second on the webber carb that I got Im not sure how to hook up the electric choke the old carb had the white clip with all the emisions crap on it how do I hook up the choke from the old harness.
PostPosted: Tue Mar 11, 2008 7:11 pm
on some like mine and my suns we had to add washers because the stud coming out has the smooth spot on it after the threads and the nut hit that before it is completely tight... gust add a few washers and it will take care of it or at least it did for us... as for the choke it needs a hot wire is all... i used the one that was going to the stock carb
