It is currently Mon May 25, 2026 6:08 am
 Post subject: 2000 S10 Rear end swap?
PostPosted: Sun Feb 24, 2008 8:51 am
I have seen alot of post on here to do an s10 rear swap. I just picked up a 2000 s10 rear from an auto v6 complete rotor to rotor for $100. But the question I have is does this year bolt in? I havent measured it yet because it is at a friends shop. The yard I got it from said I could come and swap it if it does not fit so that is why I am asking.
Th plan is to get a set of Moser C-Clip Axles that fit an S10 with the Luv bolt pattern. I already contacted moser axles and they said that is fine. So a set of alloy axles for $235.00 shipped. This is going behind a 327/TH350 that has a mild build. Any input would be great.
PostPosted: Sun Feb 24, 2008 12:05 pm
Not exactly a bolt in, you'll have to move the spring pads. Also, the rear is a couple of inches wider than the LUV one, but if you are getting new axles with the c clip eliminators, you can narrow it, the axle cost will be the same.
PostPosted: Tue Mar 04, 2008 8:28 am
My 2004 seemed to fit in without any problems at all, but you might want to measure anyways.
I think the measurements are 54" from flange to flange, and 39.5" from center of housing to a perch.
A.j.
