It is currently Mon May 25, 2026 6:08 am
 Post subject: My luv doesn't run!! :(
PostPosted: Sun Jun 03, 2007 6:54 pm
this is history, I have chevy luv with 350 V8 everything was good until a day doesn't run, i replace the battery and the starter also the ground cable and the positive cable, and still nothing, i tried to run directly in the starter with a screw driver and also doesn't work the starter was stoked, any way any body has a suggestion ??
PostPosted: Sun Jun 03, 2007 9:11 pm
Try turning the eng. over with a wrench. Make sure it didn't seize, or a broken valve has it stuck.
 Post subject: It is runing again
PostPosted: Sun Jun 03, 2007 9:47 pm
I did, I turned the enigine with a wrench and works THANKSSSSSSS
See ya
Tanhks very muchhhhhhhhhh
PostPosted: Sun Jun 03, 2007 9:52 pm
Well that eliminates a really bad problem at least. Check for a fusible link somewhere.
So it won't turn over right? Not even a click?
