It is currently Mon May 25, 2026 8:37 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Fri May 11, 2007 2:16 pm
Did you ever figure it out Blove22? I swear, i am in carb hell right now. I have two carbs, one a fairly new remain Hitachi that came with the truck and the other is a Weber. My Weber is awesome except for the fact that it wants to keep running when i shut off the key........... Is there anywhere that sells the idle stop solenoid for the weber? It seems to be tuned well, I just dont know where to go next.
 Post subject: .
PostPosted: Fri May 11, 2007 2:22 pm
My Hitachi carb had that prob, turns out it was the fast idle compensator for the A/C... even though I was not yet running AC, the little plunger that advances the throttle would hold the rpms up just abit right before I shut down. Had to stick the toe of my shoe under the pedal and pull forward then shut down to keep from deiseling. later installed a return spring on the pedal arm.
Havent had that issue with the weber
FIAA: Color Guard
PostPosted: Fri May 11, 2007 2:57 pm
yeah finally got it working pretty good. it turned out to be the screw that adjusts the throttle from the linkage thing. i hac\ve no idea how i fixed it i just started turning the screw and it worked.
PostPosted: Fri May 11, 2007 3:23 pm
I know which one you are talking about, I thought that was the fast idle screw? Which way fixed the dieseling, CCW or CW?
PostPosted: Fri May 11, 2007 3:40 pm
ccw, unscrew it alittle till you fill comfortable with it. if this doesnt foix it, loosen the screw to you dist. and turn it clockwise just a hair. mark the normal position before you turn it for a reference point. youll just have to play with both of these things, thats what i did and it fixed my problem.
 Post subject: .
PostPosted: Fri May 11, 2007 7:09 pm
http://webernorthamerica.com/pdffiles/w ... gguide.pdf
FIAA: Color Guard
PostPosted: Sat May 12, 2007 10:22 am
Well, I think that the problem has been nullified. The screw in question is the fast idle screw i believe. I adjusted that to get my fast idle to 2k to 2.5k when it is first started up. How i believe i fixed the dieseling is I fabricated a bracket like Ctmandu and used the old throttle assy plus the spring that returns the throttle to idle when you let go of the gas. I think that that was my problem all along, the post by 79-LUV'r about the A/C thing got me thinking about it, and sure enough, it seemed to fix the issue.
 Post subject: .
PostPosted: Sat May 12, 2007 10:39 am
Sahweet!!
FIAA: Color Guard
