It is currently Mon May 25, 2026 12:21 pm
 Post subject: 76 disc swap problems
PostPosted: Fri Apr 27, 2007 7:40 pm
So i got all the new parts calipers, mastercylinder,booster,pads, etc... took off all the old parts a found out that the calipers i got dont even lok like they would fit. i cant figure out how to put them on so if anybody could post some bettter pick of there calipers. that would be helpful thanks
PostPosted: Fri Apr 27, 2007 8:12 pm
Are you swapping from drums to disc ? If so you might need the brackets that go from spindle to caliper .
PostPosted: Fri Apr 27, 2007 8:46 pm
Did you have a look at the article Ben did in the info section? One of the pictures answers your question.
http://www.luvtruck.com/Information/Brake_swap.htm
