It is currently Mon Jun 08, 2026 7:19 am
 Post subject: Fan sheld
PostPosted: Sat Mar 25, 2006 12:15 am
Dose the fan shelled make a big difference in keeping the motor cool
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Sat Mar 25, 2006 6:11 am
yes, it helps pull the air directly to the center of the radiator.
PostPosted: Sat Mar 25, 2006 6:23 am
yeah you need it so the air is pulled properly by the fan.
PostPosted: Sat Mar 25, 2006 2:03 pm
Yes. You need a fan shroud.
My 78 was doing fine without one, but I happened upon one so we put on there.
PostPosted: Sat Mar 25, 2006 2:54 pm
same here drove for 2 years with out one and never had a problem . when i did the rebuild i found one and it does run cooler by a little bit
PostPosted: Tue Mar 28, 2006 9:15 pm
what type of vehicle did you get the shroud off of
Arquing with me is like running in the special olympics, even if you win your still retarded.
PostPosted: Tue Mar 28, 2006 9:16 pm
off another luv
PostPosted: Tue Mar 28, 2006 11:02 pm
Chavy, do you need a fan shroud?
PostPosted: Tue Mar 28, 2006 11:32 pm
I would like one
79 4x4 1.8 liter
PostPosted: Wed Mar 29, 2006 1:05 am
If you remind me, "RIGHT" before the meet, i'll bring you one :wink:
Users browsing this forum: Google [Bot] and 30 guests
