It is currently Mon Jun 08, 2026 7:18 am
 Post subject: heater box
PostPosted: Mon Mar 13, 2006 1:56 pm
noticed the other day that when I slide my heater control thing from def to heat, right before it falls into the heat slot, it goes really hard. Just curious if this is going bad on me because it has always slid over so nice in the past.
Most people think of their skin as an ally. Makes me rethink having skin at all
PostPosted: Mon Mar 13, 2006 2:09 pm
it might just need lubed or adjusted... it's real easy to check.
PostPosted: Mon Mar 13, 2006 3:01 pm
can I just shoot some penetrating oil in there?
PostPosted: Mon Mar 13, 2006 3:15 pm
i'd check the cable ends where it hooks up on both ends and make sure they are not binding up and then try some lube on it. Mine had a cable slip a little and it would bind up hard and it ended up bending the lever where it attached to the heater controls.
PostPosted: Mon Mar 13, 2006 3:59 pm
so do I have to pull the box out? if so, whats an easy way of doing so?
PostPosted: Mon Mar 13, 2006 4:19 pm
you shouldn't need to pull the box out. you can pull the heater controls off but it's not really neccessary. Just crawl under there and look around as you move the controls and you can see which one is for what. then go from there
Users browsing this forum: Google [Bot] and 30 guests
