It is currently Mon Jun 08, 2026 5:56 am
 Post subject: well im in a pickle
PostPosted: Wed Mar 08, 2006 1:05 pm
hey guys i need some advice big time ok . my 78 hasent rau sense the motor rebild and i fuond the prob the head was off 180 deg. from the pistons (dang i cant spell in a hury) and i lined it back up i think i mifgt be 3 or 4 chain length off because my carb is spitting then the exaust spits ti really suonds like it wants to run and it just like fireing but not compleetly
what could it be needing opions
my frends dodge says its eaten chevys and shiting fords well i say AT LEAST ITS EATING SOMETHIMG GOOD
________________
1978 LUV
1980 4X4 LUV
1977 LUV
PostPosted: Wed Mar 08, 2006 1:33 pm
Check out this recent thread in drivetrain upgrades. In my last post in there I cover how to verify the cam/crank alignment. http://forums.luvtruck.com/viewtopic.php?t=9702
To be honest though, your description of the symptoms sounds like the truck I have that is 180 degrees out. Shot flames out the carb and backfired like a cannon out the pipe. I just swapped wires on the distributor though. If you find the cam does not match the disti (Should be: rotor at #4 on disti, cam mark&dowel straight up, crank at 0 degrees, 180 out has disti pointing to #1) the easy quick solution is to swap the plug wires. Switch 1 for 4 and 3 for 2, should fire right up if all you are is 180 degrees out of time.
PostPosted: Wed Mar 08, 2006 2:17 pm
thanks 800xl
________________
1978 LUV
1980 4X4 LUV
1977 LUV
