It is currently Sun Jun 07, 2026 1:10 am
 Post subject: diesel block
PostPosted: Sun Feb 09, 2003 5:38 pm
can i use the deisel block but use all the parts from the gas like head intake front timing cover and oil pan. isn't the diesel a 2.2l? and will it bolt up to the gas tranny? i think if this is possible i would be pretty cool.
PostPosted: Mon Feb 10, 2003 4:11 am
i'm not a diesel expert or anything, but i would think not. I know diesels have higher compression, so it probably wouldn't be wise to use the gas aluminum head if it even bolted up. :?:. and if the head doesn't fit then other stuff probably wouldn't either. Like i said though I'm no expert and the only work i've done on them is change oil :oops:. Don't diesels use a form of fuel injection ?
PostPosted: Mon Feb 10, 2003 7:19 pm
same here, no expert, but because of the compression, a lot of heads have like 30% more head bolts. Probably wont line up. Also is there a spot for a distributor in the block, and gears for it on the crank.
Its a phononm0onommomnnomn....menon.
PostPosted: Mon Feb 10, 2003 9:30 pm
I put a gas head on a diesel VW rabbit... but i dont know anythign about the diesel in a LUV
PostPosted: Wed Feb 12, 2003 3:38 pm
well i think i will try and get a diesel block cause i have a spare motor that is in pieces and i am pulling out n e way for another 1.8 so i thik i will do a little experamenting. it couldn't hurt n e thing unless i force it but i will try not to. i will tell u guys how it goes when i start
PostPosted: Sun Feb 16, 2003 9:25 pm
I couldn't see the 1.8 liter gas engine and 2.2 liter diesel engine being similar in the engine parts. You would have better luck if you tried the 1.9 liter or 2.3 liter gas engines from the Isuzu PUP.
