It is currently Fri Feb 20, 2026 1:24 am
 Post subject: MOTOR REBUILD KIT????
PostPosted: Wed Jan 25, 2006 7:10 pm
can anyone tell me where the hell to find a master rebuild kit for a 73 luv motor?????? I have found all of the stuff separate but i would like to get them all at once.... I'm generally a chevy small block guy and i wanted to try something different so i'm going to keep the stock motor and turbo it.
PostPosted: Wed Jan 25, 2006 7:34 pm
I've seen turbos on the 76 and newer style of motors, but never on an old style, that should be interesting.
As for a rebuild kit that might be tough. The early style motor is getting very hard to find parts for these days. http://www.rockauto.com shows a full gasket kit, but you would need to add rings, pistons, main & rod bearings, probably a few other items. Rockauto seems to have most of it, but I don't see pistons listed.
Seems like I've seen a full rebuild kit and a re-ring kit in the JCWhitney catalog but I can't find it looking through http://www.jcwhitney.com Their website isn't the easiest to find anything on though. You might also check with FelPro/Sealed Power (click them for link) and look through their catalog. If anyone makes a full kit it would them, and that would give you a part number to hit up your parts dealers with.
 Post subject: thanks
PostPosted: Wed Jan 25, 2006 7:44 pm
I found alot thanks to your links.
i have been sitting on this truck for 2 years trying to figure out what to do... i see alot of small blocks so i figured i would go a different route, i've built alot of stuff but i've never really done a turbo so this should be interesting
