It is currently Tue Jun 09, 2026 12:20 pm
 Post subject: 78 chevy luv with issues
PostPosted: Sat Jan 21, 2006 12:20 am
Ok i'm not a luv truck guy i'm a BRAT guy. but one of my friends has a sweet 78 and he pulled the motor to put in a trany and now it wont start. it is getting gas its getting spark, the engine timing is perfect, flipped the disributer 180 degrees, the firing order is right and still nothing but turning over. if any of you can give me some ideas that would be awsome.
thanks,
Matt
PostPosted: Sat Jan 21, 2006 1:43 am
does it just turn over and over?
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
 Post subject: 78 luv with issues
PostPosted: Fri Jan 27, 2006 12:17 am
yes it does turn over but i forgot i did not check all plugs for spark just the first cylinder. im going to check that next time i go to his house. but if its firing on all cylinders what could it be?
thanks in advance,
Matt
PostPosted: Sat Jan 28, 2006 9:47 am
if you have spark, you need air and fuel. is it getting fuel? vac lines where they need to be?
Resident lurker
PostPosted: Sun Jan 29, 2006 1:21 am
yeah all the vac lines are where they need to be and there is atleast fuel going to the carb. its not flooding out the float bowl is not going dry the distributer has been flipped 180* and it still wont fire up but it will turn over. i'm going to see if there is a crack somewhere and test all plugs for fire, but if thats all in order what could it be?
PostPosted: Sun Jan 29, 2006 2:12 am
Just pulling the motor should not have done anything at all to how it runs. Most likely thing seems like it would be a loose wire that didn't get hooked back up. Wires to the carb all hooked up, wire to the distributor on good, condensor hooked up? The distributor only goes in one way, so you can't put it in backwards. Get it timed, check the point gap, make sure all the right wires are hooked up, and it should go.
Just keep double checking things and I'm sure you'll get it going again. Even if you think you've got fuel, it wouldn't hurt to try pouring a bit down the carb. If that gets it to pop over some then you know where the problem is.
 Post subject: thanks
PostPosted: Sun Jan 29, 2006 4:13 pm
thanks for your help with this chevy luv i am going to go over there and check every thing out as soon as i can.
thanks again,
Matt
Users browsing this forum: Baidu [Spider] and 38 guests
