It is currently Mon Jun 08, 2026 7:18 am
PostPosted: Sat Jan 14, 2006 2:59 pm
That is the longest my truck ran with out someone on the gas petal in 18 months. Amazing what some vacume line will do.
It ran until I reved it up to 4K then sputterd and died when it was just about back down to idle. I will have to work on that next.
WOO HOO!!!
Rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
 Post subject: dies when revup.
PostPosted: Sun Jan 15, 2006 7:03 pm
Aha. fuel pump or fuel filter time. pump #3 on mine.
1980 Luv 4X4
another 1980 luv 4x4
PostPosted: Sun Jan 15, 2006 7:39 pm
It is good to hear someone making some progress!!
giddy up!
!!!FINALLY!!!
-1977 Luv mikado
PostPosted: Mon Jan 16, 2006 4:50 pm
Both new, I think it just needs some tweeking but I am so close....
Better yet let me put it this way:
New Tank
New Pump
New Lines
New New New!!!!!!
hoorah!!!!!
Now when it gets warmer time to break out the paint brush....
Rigel
PostPosted: Mon Jan 16, 2006 5:50 pm
I prefer rollers for all my automotive painting, you get that rich textured look. Also it is fun to sponge on a faux finish like stucco or a masonary look, adds that special touch to a good automotive paint job.
I'm just funnin with ya though. Could be some crud in the carb. Pull the inlet and check the screen that is in there. If it is full of crud it would act just like a fuel pump problem. Sounds kind of like there is stuff down in the carb though, might take a while to flush it all out if you had a lot of gunk going through it in the first place.
PostPosted: Tue Jan 17, 2006 7:47 am
By your command........
Checked it no crud.... Might be the spark plugs they could be fouled from all my attemps at getting it running. I does sound like it is missing.
Rigel
Had to make the BattleStar joke....
PostPosted: Tue Jan 17, 2006 8:56 am
i've been waiting for that... :D
