It is currently Mon Jun 29, 2026 10:19 pm
 Post subject: Hitachi help
PostPosted: Sun Oct 02, 2005 8:29 pm
what are some tips on tuning one of these POS carbs? Weber soon but not an option right now money wise. The damn thing was just rebuilt. The truck wont start but just turns over an over. it spits gas back out the choke side and acts like its got no spark. It did run before the carb was rebuilt, not very well but it did run.
 Post subject: POS Hitachi
PostPosted: Mon Oct 03, 2005 10:58 pm
Sometimes it's impossible to tune 'em. The last rebuilt one I had came with worn bushings on the primary throttle plate shaft. Gas was literally dripping out. So now I run a Weber. But! Try yanking all the quarter inch vacuum lines except spark advance and cap or plug the ports. That'll eliminate possible vacuum leaks.
PostPosted: Tue Oct 04, 2005 4:55 pm
It really seems to be more art and luck than any particular skill. The last several times I've worked on a stock carb I've ended up getting it right. I couldn't say how exactly, other than I must have some good Hitachi Karma built up. The 79 I sold worked 100% perfectly when I got done tuning it, the 77 my wife drives is fine other than it needs some tweaking to the linkage (won't adjust idle below 1k, but the secondary seems to open on the early side and give it some pep) and the 79 I have now was running perfect with the stock carb before I swapped on a Weber.
My 32/36 weber on the other hand has been a pain in the neck. The electric choke is either way over or way under choking, and the least little bit of crud gets into the strainer screen and its like I unplugged the fuel pump. Oh well, starts hard hot or cold but it runs like a racecar going down the highway. ;) It probably just needs a rebuild and some cleaning up though. My 32/32 Weber worked great, but I got tired of having to deal with the manual choke all the time.
I think getting a Hitachi to run right just requires patience, a carb that isn't worn out to start with (or new shaft bushings) and some luck. I struggled with mine for years, maybe now I've just got them broken in. Only real tip I can offer is that the mixture setting is about 3/4s of the problem usually. Get that dialed in and the rest usually won't keep it from running. That and I'd never have someone rebuild one for me after the horror stories I've read here. Rather do it myself with maybe a machine shop trip for doing the shaft bushings.
PostPosted: Wed Oct 05, 2005 3:26 am
I would have done it myself except I have never rebuilt a carb :oops: I'm gettin more frustrated with the fact the danm thing wont start now, just keeps turning over
PostPosted: Wed Oct 05, 2005 3:52 am
will it run, if you pour gas down the carb???
PostPosted: Wed Oct 05, 2005 4:07 pm
nope, thats about the only way we could get it started before, but like I say it acts like its not getting any spark now. points look good, fairly new cap and plugs. It still has the bad manifold on it but it ran last time with it. I just wanted to get the damn thing running before I swap the header on
PostPosted: Wed Oct 05, 2005 5:36 pm
I know little of carbs. To steal a line from one of my favorite movies....
"My advice......start drinking heavily." :lol:
1980 2wd Stock
 Post subject: Start
Pull a spark plug wire off a Plug. Stick the end of screwdriver in the wire and lay it on the block somewhere next to metal. Crank the engine to see if a good spark jump from the screwdriver blade to ground.
PostPosted: Wed Nov 02, 2005 11:49 am
Im in Hitachi carb tuning hell myself... Do you see fuel in the fuel bowl? Do you see fuel shoot out of the accelerator pump? Start with the basics..
LUV Truck Desserter!
76 Daily driver (SOLD)
63 Nova
74 Camaro
Users browsing this forum: Baidu [Spider] and 50 guests
