It is currently Mon Jun 29, 2026 4:31 am
PostPosted: Thu Aug 19, 2004 6:41 pm
Luvtruck.com Wookie
ok..... i give up.... how the hell do i PROPERLY set the choke on this damn thing.
i've tried warming it up all the way and setting it to just barely close the butterflies, but then it won't start easy when it's hot out.
what gives? they didnt send me any literature besides the float level instructions and a parts list. the rebuild kit for my craptachi did though.
TiLtEd wrote:
Boobies!!! :D
 Post subject: Choke
PostPosted: Thu Aug 19, 2004 7:44 pm
Chokes are set cold. Usually to less than 1/16" closed. Best done early in the morning, when it's coldest.
PostPosted: Fri Aug 20, 2004 2:25 pm
(Pierce manifolds) has a conversion for the weber DGV for the electric choke to switch to a pull choke if you cant get it. Ck web site If hitachi good luck.
My hitachi
I adjusted once and never got it correct on my Datsun521. Seemed like it worked when cold then warm wouldnt idle or when cold whould not work but warmed up was OK. I said hell with it!!! put a weber DGV on
 Post subject: How to adjust...
PostPosted: Fri Oct 21, 2005 6:33 pm
Hey guys,
Got the DGEV on and everything is pretty good EXCEPT how do I adjust the choke? It's set right now, but the thing idles so HI for quite a while before it calms down :(
PostPosted: Fri Oct 21, 2005 10:01 pm
well the hi idle screw is on the back side of the carb under the choke thermostat. Next time you start it up cold adjust that down some, it should idle at about 1200 cold. As far as adjusting up the butterflies goes, about 1/16" open is how i have mine set and it works great.
PostPosted: Sun Oct 23, 2005 11:54 am
Luvtruck.com Wookie
What he said......i finaly got mine dialed in after 6 months......i actualy used a dime for the gap. the high idle does change quite a bit, i had to change mine every summer and winter since we have a huge diffrence in the climate.
also after you get it set, if you have an abnormaly cold morning it will run really fast for a minute or two. it doesn't hurt though, your cam wears more at low rpm and a high rpm just gets the oil flowin quicker anywho.
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Oct 23, 2005 6:23 pm
i dont have my hi idle set up becouse it was so goofy. And i just eye balled my choke gap so its not realy an exact science.
Users browsing this forum: Google [Bot] and 114 guests
