It is currently Sun Jun 28, 2026 11:27 pm
PostPosted: Sat Oct 15, 2005 3:44 pm
i sent pixs but they haven't been posted yet. its only been 2 weeks tho..... any how; my alernator on my stock 1980 chevy luv 4x4 is bad. i have factory ac and radio. its stock 1.8 ltr engine, with the manual tranmission.
heres my question; does anyone know if its a 35 amp or 50 amp alternator?
i wanna avoid excess trips walking to auto zone. i haven't gotten it out of the truck because "my mechanic"(friend who i begged)isn't ready to work on it yet. i'm trying to get everything ready .
my mother in law says theres no such thing as the alternator belt, that its just a reg belt put on the alternator;
i say no there is such a thing
whos right?
Happiness is stroking the lizard
(what?! i have a five foot iguana;
what were you thinking ;) )
OUCH!
got luv bumps?
PostPosted: Sat Oct 15, 2005 7:45 pm
whos right?
PostPosted: Sat Oct 15, 2005 7:53 pm
With factory ac it should be the 50.
As for the belt...well why don't we compromise and say it's a v-belt. Or possibly as the factory manual calls them "Drive belts"
Resident lurker
PostPosted: Sat Oct 15, 2005 11:19 pm
thanks i was assuming the 50 b/c of ac.
so when i change the alternator i ask for a drive belt then?
b/c i might as well replace that too.
thank u :D
OUCH!
got luv bumps?
PostPosted: Sun Oct 16, 2005 6:36 pm
I would think you could just ask for the alt. belt for a ??year and ??motor for a luv. Shouldnt be any more complicated than that.
PostPosted: Sun Oct 16, 2005 10:23 pm
ya i thought that too. i have sevice recipts that call it an alternator nelt,
hopefully my pix i sent get posted soon
OUCH!
got luv bumps?
PostPosted: Sun Oct 16, 2005 10:24 pm
ooops alt Belt
OUCH!
got luv bumps?
PostPosted: Mon Oct 17, 2005 3:23 pm
I have a 35 amp alternator but I plan on puting some of road lights on my truck could I put a 50 amp alternator to get more power but I dont have ac would it work?
If you cant find it grind it
79 4x4 1.8 liter
69 Jeepster comando v6
PostPosted: Mon Oct 17, 2005 4:55 pm
it would work just fine
PostPosted: Mon Oct 17, 2005 5:28 pm
are all the bolts the same and the belts
79 4x4 1.8 liter
PostPosted: Mon Oct 17, 2005 5:32 pm
should be
PostPosted: Mon Oct 17, 2005 10:36 pm
Actually from what I saw on my 79 the A/C and non-A/C alts are exactly same, but the A/C version has a smaller pulley so it turns faster. It is hard to tell for sure if they are internal identical, but that is all I can see for differences.
The parts book does show different part numbers for a lot of the internal and external parts though, including the case. It didn't look different to me though, and the smaller pulley would explain the boosted output.
Every place I checked lists the same voltage reg for A/C and non, so it should not make any difference which you use when replacing the alt.
PostPosted: Wed Oct 19, 2005 8:33 pm
im running a 50amp alt on my truck right now. Only diference is its demensionally a little bit bigger. Everything works though (bolts/brackets and the belt).
Users browsing this forum: Bing [Bot] and 46 guests
