It is currently Mon Jun 08, 2026 4:27 am
 Post subject: Cylinder Head
PostPosted: Sun Aug 21, 2005 10:54 am
I'm in the process of removing the cylinder head on my stock '79 Luv to change the gasket. After getting the cam cover off, my manual says "turn cam shaft until piston 4 in firering position". My question is, how do you turn the cam shaft, and how do you know when piston 4 is at TDC when you can't see it?
PostPosted: Sun Aug 21, 2005 12:12 pm
put a screwdriver in the hole and turn the crank until the piston is at tdc
PostPosted: Sun Aug 21, 2005 6:01 pm
When the timing mark on the crankshaft pulley is at 0 degrees, you have either #1 or #4 at TDC. Pull the distributor cap and see which one it is pointing at and you are set. You can also tell by which valves are open or closed, but I don't remember off the top of my head what they are supposed doing for #1 or #4 and I don't have my book handy.
I take baling wire and wire the chain to the camshaft gear before removing it. This keeps your valve timing dead on and you just have to line up the cam the same way as it came off when you reassemble. It is also a good idea to loosen the valve adjustments all the way before setting the head back down. That keeps the valves up out of the way so you don't hit a piston with one, or nick the gasket.
Users browsing this forum: Baidu [Spider] and 35 guests
