It is currently Tue Jun 30, 2026 1:52 pm
 Post subject: Shackles!
PostPosted: Fri Jan 17, 2003 10:17 pm
I would appreciate you guys telling me what kind of shackles I would need for the torsion lift on my 81 4X4 and where I might be able to find them. Thanks :lol:
PostPosted: Sat Jan 18, 2003 2:31 pm
Resident Sparktrician
For the front you don't need anything except an impact wrench and a socket to fit the torsion bar adjuster bolts. For the rear, I would say look on JCWhitney's site. I think that's where I saw some.
Good luck,
Jon
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Sat Jan 18, 2003 4:43 pm
i lifted my front end with torsion bars 3 1/2 in and if i went any higher i would have had the stiffest suspension ever so i don't recomend going over that. you could go and lift your truck 2 inches with shackles and torsion bars then get a body lift i had a website that sold 2 in and 3 n so i will try and find it and tell you but that might be the best thing to do
PostPosted: Sat Jan 18, 2003 4:59 pm
i found the website. its a little ways down but its on therehttp://www.tyres1.com/search/searc ... _code=PABL
i am thinking of getting the 2 inche lift so if i get it i will tell you how it is
PostPosted: Sun Jan 19, 2003 3:12 pm
I found some shackles on calmini's website but they were 50 bucks. Most of the guys here got their's for about 20. Where should I look for some cheaper shackles. Thanks for all the info guys. :twisted:
PostPosted: Sun Jan 19, 2003 4:37 pm
autozone sells a "universal" set that may work.
PostPosted: Mon Jan 20, 2003 4:57 pm
Well for my 2" lift all i did is extend the stock shackles to 5" long. I torched em in half then mig welded a piece of 2" plate on either side. I wouldnt recomend this unless your a vary good wleder. Ow and doing it this way cost me about $2.50
Users browsing this forum: Google [Bot] and 45 guests
