It is currently Mon Jun 08, 2026 3:18 am
PostPosted: Wed Jul 06, 2005 5:57 pm
Ok here is the plan crazy as it seems.
There is a V8 out there that is solid and pretty strong. And it weighs as much if not less than the 1.8,
I am thinking of some how getting this engine in the truck with a transmission 4 spd? that will fit and the only thing I need to do is change the lenght of the driveshafts.
Does anybody know of the engine I am speaking of........
hint it's a american engine
Rigel
81 LUV 4x4 Red Was a heavy hauler now is back to mostly stock config.
http://www.Rigeltech.com
PostPosted: Wed Jul 06, 2005 6:42 pm
i belive it a northstar v8, they have aluminum blocks so they are very light
PostPosted: Wed Jul 06, 2005 6:46 pm
you are right about the allum.
But think much older....
Rigel
PostPosted: Wed Jul 06, 2005 7:36 pm
olds/buick 215 or 300 v-8. it had alum block, heads and intake. this engine evolved into the v-8 engine in the mg and later in the land rovers. it could be had with a turbo back in the early '60s in the old jetfire and later variants had efi in the land rovers.. it has the B-O-P bellhousing bolt pattern and it a fairly light motor. the homebuilt aircraft companies had kits to use this motor due to it's light weight.
PostPosted: Thu Jul 07, 2005 4:00 am
Thats the one the buick 215 now to figure out a 4x4 tranny that will bolt up to it and fit in the LUV
Rigel
PostPosted: Thu Jul 07, 2005 11:32 am
Banishment Pending
How about a MUA5 out of a 1989-91 Trooper that had the GM V6?it has the GM 60* V6 bolt pattern
