It is currently Mon Jun 08, 2026 3:17 am
 Post subject: Rear light wiring?
PostPosted: Sat Jun 25, 2005 2:48 pm
Is there a plug or whereis harness for the rear end of a1980?
Having trouble with the tail light .
Any ideas are welcome.
Thanks
PostPosted: Sat Jun 25, 2005 2:52 pm
i don't think i understand your question, but the plug for the tailight harness on an 80 is behind the license plate on the frame. if ya need more help let me know as I had major issues with the taillights on my 80
PostPosted: Sun Jul 17, 2005 8:06 am
HA HA Ha just read my post!
No wonder I only got one reply.
I must have written it in my sleep.
Yes, thank you I can sure use some help.
First we thought it was the switch..cleaned it up, tested it works fine.
Now the
the rear light are ALL OVER the place.
The back up light blink and buzz with the ignition start warning buzzer.
Any help would be welcomed.
NOTE: I never had the light in back working previous owner did a butcher job of wiring.
PostPosted: Mon Jul 18, 2005 3:01 am
Butchered wiring doesn't sound like fun. You might want to take out the tail light assemblies and unplug from the wiring harness and check the connectors for dirt and corrosion. When I was repairing my reverse lights I had a hard time with the wiring harness and there was some mud caked in them a bit and the pins on the connectors were slightly corroded. When I plugged them back it things were messing up some, but after plugging and unplugging them 5 or 10 times and blowing all the dirt out of them, I got them to work fine. Make sure they are connected in all the way and tight too. Electrical connections have to be clean and tight. Good luck and hope you get your problem fixed.
http://www.purerockradio.net/
Users browsing this forum: No registered users and 61 guests
