It is currently Mon Jun 08, 2026 3:17 am
 Post subject: points keep frying
PostPosted: Sun Jun 12, 2005 11:41 pm
i have a stock engine and my ignition points and distributor points keep frying, i replaced the points and condensor and the points melted within 5 kms. i attached the old condensor and didnt have a problem til recently, i went on a long drive interstate and it happened again. what could be causing this?
PostPosted: Mon Jun 13, 2005 12:56 am
If the coil is not running through a resistor it could cause the points to fry pretty fast. With the truck running you could check the voltage between the + side of the coil and a ground (- post of the battery would be good since its close) If it is 12 volts then the coil isn't being powered through the resistor when the motor is running. When everything is working right, the coil gets full 12 volts when the key is turned to START via a relay. Then when the key is released to ON and the motor is running power to the coil is routed through the resistor. The relay is one of those under that mystery metal cover on the left inner fender.
PostPosted: Wed Jun 15, 2005 10:35 pm
yeah your right, it was the resistor, i wasnt running one at all. i spoke to an auto elec and he told me how to rig one up, basically putting it allong the + of the coil.
PostPosted: Wed Jun 15, 2005 10:54 pm
if you need one i have few from my other truck i would send your way.
PostPosted: Wed Jun 15, 2005 11:15 pm
hey mepr you wouldnt happen to have a headlight bezel for the passenger side do you
thanks
billy
PostPosted: Wed Jun 15, 2005 11:41 pm
i have everything... :lol:
seriously though ill pm you.
PostPosted: Thu Jun 16, 2005 10:10 pm
thanks for the offer merp but i got a coild n resistor from my loacl wrecker
