It is currently Mon Jun 08, 2026 3:07 pm
 Post subject: No turn signals
PostPosted: Fri May 20, 2005 1:16 pm
OK I finally got my 75 back on the road, now my turn signals wont work. I checked the fuse and its ok; the horn and turn signals are on the same circuit and the horn works. Does anybody have any suggestions what could possibly be the problem?
PostPosted: Fri May 20, 2005 2:24 pm
check your connectors and your bulbs, they may need a little cleaning.
PostPosted: Fri May 20, 2005 3:08 pm
Does the turn signal light on the dash come on solid? I had the same issues with mine. Had been sitting for almost 8 years exposed to the elements, and the wiring connections / bulbs just needed a little TLC.
PostPosted: Sat May 21, 2005 9:26 am
Definitely couldn't hurt to check the bulb sockets. Every problem I have had with my lights aside from the headlights has been rusty crusty sockets. dremel with a wire wheel and good as new.
Resident lurker
PostPosted: Tue May 24, 2005 2:12 am
Remember to check the flasher?
