It is currently Mon Jun 08, 2026 10:27 am
 Post subject: lift kit
PostPosted: Tue Jun 21, 2005 5:09 pm
1980 luv 4x4,want a lift kit but don't know what is available for this truck.i know i can get a 3 inch body lift but i was thinking more on the lines of suspension.just some info would help,thanks
SANDMAN
PostPosted: Tue Jun 21, 2005 8:25 pm
crank the torsion bars up in front and then weld up some extended schacles for the rear. Thats about the only option for a suspension lift.
PostPosted: Wed Jun 22, 2005 12:28 am
Mepr has it pretty much covered unless you get real creative with a welder. You can expect around 3 inches from cranking the torsion bars in the front. In the rear you can go with extended shackles (make em yourself or they can be bought quite a few places) or you can change/add springs. You could rework the rear spring mounting to put the springs onto the top of the axle (aka SOA or Spring Over Axle), but that would give you about 6 inches which you could not match in the front. Combine SOA with removing some spring leaves and you might find a good balance.
If you want a source for general info and parts for Isuzu suspension lifting check out http://www.independent4x.com and look at their FAQ and lift parts sections. They don't focus on LUVs so much, but I'm sure there are some parts that would help. I got poly spring bushings there for my 86 Isuzu Trooper and they also fit my LUV. If you want to really lift the front, you can also browse the front axle section for SAS (Solid Axle Swap) info.
PostPosted: Fri Jul 01, 2005 12:48 pm
Banishment Pending
And thats about all you can do unless you want to make a FrankinLuv!!!
Users browsing this forum: Google [Bot] and 28 guests
