It is currently Tue Jun 30, 2026 6:35 am
 Post subject: VIN number locations
PostPosted: Wed Mar 09, 2005 9:56 pm
Got a quick question for y'all. Where are all the locations of the VIN on the LUV? Just curious and may need to know as I may be changing the cab on my 79 longbed. Thanks!
PostPosted: Wed Mar 09, 2005 10:39 pm
Should be a tag on the drivers door jamb and the last few numbers stamped below the cowl on the pass side. other than that I don't know...
Resident lurker
PostPosted: Tue Mar 15, 2005 12:07 pm
Those are the only two I have found so far. When I'm done stripping mine I should be able to find others if they were not removed.
PostPosted: Tue Mar 15, 2005 6:20 pm
Thanks! I'm gonna need that info because I'm using two trucks to make one good truck and I'd like it to be legal when I'm done!
PostPosted: Tue Mar 15, 2005 11:10 pm
check the crossmember that the transmission mounts to
PostPosted: Tue Mar 15, 2005 11:29 pm
Thanks I'm taking mine out to cut up so I can lay another inch. I'll take it down to bare metal like the rest of the truck will be and take pics to show exactly where it is.
PostPosted: Wed Mar 16, 2005 11:24 am
I appreciate your help guys! If there are any other VIN locations, please let me know ASAP! I'm gonna be doing the body work next month and want to make sure all the VIN's match when I'm done.
