It is currently Mon Jun 08, 2026 7:11 am
 Post subject: Steering Rag Joint
PostPosted: Mon Jan 10, 2005 9:41 pm
I didnt' tighted my collars on the Rag joint that connect to the steering columand the steering box. As a result it stripped the teeth in the collars.
I dont really want to get the ones out of a Junkyard, this is a part that
I dont want to give out. Its not fun when you looseing control of steering while driving. Has anyone else replaced the joint or put in a differnt steering column? I thought about welding it. But the local mechanic doesnt want to get sued if the weld breaks.
PostPosted: Mon Jan 10, 2005 11:59 pm
Did you strip the collars and the steering colum? If you didn't strip the colum and you just stripped the collars you can replace the collars.
 Post subject: collars
PostPosted: Tue Jan 11, 2005 9:02 pm
The colum looks pretty good. I still dont like the idea of the collar being used and put on there. I need somone to weld it to be on the safe side.
PostPosted: Tue Jan 11, 2005 9:33 pm
Just get some different collars and make sure they are tight, I've never had a problem with those collars, so as long as there tight you should be ok.
I had a camaro steering come loose going around a corner the spline sliped right out of it, that was scary, the steering whell just span freely in circles, good thing i wasn't going that fast.
 Post subject: Mahinest?
PostPosted: Sun Jan 16, 2005 5:01 pm
I got another Rag Joint out of the wrecking yard and
a differnt steering column. The newer column has two splies that are bunged up at the base of the splines. I took a small file and ran the file
inbetween the grooves.
Should I go ahead and put it together or should I go to a machinst (Can they fix splines?) Or should I just get anothoer column?
I can post pics if that will help. Thanks!
PostPosted: Sun Jan 16, 2005 6:30 pm
just clean up the splines and put it together. you'll be fine with that, just make sure everyhting is seated and tight
