It is currently Mon Jun 08, 2026 10:19 am
 Post subject: bad sign?
PostPosted: Wed Dec 29, 2004 10:28 am
Luvtruck.com Wookie
i towed a junker down to pick and pull last week and my truck seems to be missing oil now......
i thought i had burned some up towing the load, but i filled it back up and now it's two quarts low in two days.
i inspected the front and rear seals and the're good, i don't think i'm burning it , the only place i can find something resembeling a leak is at the dipstick. when i take the oil cap/breather off there's pressure......i could probably float a ping pong ball on the air pressure but i think a golf ball(heavier) would seal it off.
is this a pressure leak? my block is a re-man .30 over so i don't think it could be the rings.....i broke it in right andthe engine has less than 10k on it since..... the head was rebuilt 5000 miles before the engine was done. but i don't know how to do a leak down, how do you tell if it's the cyl walls or the valves?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Dec 29, 2004 12:07 pm
Sounds like the PVC system is not venting as it should and the pressure is pushing oil past the rings. Check the plugs and see if they're fouled.
PostPosted: Wed Dec 29, 2004 12:16 pm
Luvtruck.com Wookie
no oil on the plugs.....i have the pcv system hooked up to the old egr intake(large port) on the intake manifold and a large hose/valve setup in the valve cover......so i don't belive it's the pcv system.....
i'm suspecting the valve guides but i don't know how to check em without taking the motor apart.
TiLtEd wrote:
Boobies!!! :D
Users browsing this forum: Bing [Bot] and 41 guests
