It is currently Sun Jun 28, 2026 8:43 pm
PostPosted: Thu Dec 12, 2002 9:35 pm
help i need to know if a speedo cable from an s 10 or some other chevy will wirk on the luv i cut my stock one to work a couple different times but u have to grind the end square and i cant seem to center it and it breaks please help :)
PostPosted: Fri Dec 13, 2002 12:03 am
I had trouble finding one for mine at the local shops. I finally took it to a speedometer shop and they had one that worked great. The guy even acted like, "ya, of course we have one".
PostPosted: Fri Dec 13, 2002 6:05 am
when I needed one, I went to a shop.....(dont even know what they did there) anyhoo they cut the end that goes in the tranny and attatched the square end that it needed.
03Cobra
PostPosted: Fri Dec 13, 2002 8:12 am
Shucks has a replacement speedo cable for really cheap and it has the square ends and end pieces with it. I think they also have 2 different lengths as well and they are both under $15. I hope that helps.
Users browsing this forum: No registered users and 79 guests
