It is currently Sun Jun 07, 2026 11:49 pm
 Post subject: dieing?
PostPosted: Thu Dec 09, 2004 9:34 pm
everytime when i try to push on the brake and gas (to burn out wet road) my truck starts running weird has no power then dies a couple mins later then it won't start at all i can get it to start for a couple of seconds then dies if i wait like 5mins it will start right up and drive fine. anyone have any ideas? i don't burn out anymore. :lol:
PostPosted: Thu Dec 09, 2004 10:47 pm
I don't know, but sounds like you already took the advice I'd give... :D
Like that saying..."Doc my arm hurts when I do this..."
Doc says "Then don't do that."
:D
Resident lurker
PostPosted: Fri Dec 10, 2004 12:27 am
lol! :lol: thanks for the help 8)
PostPosted: Fri Dec 10, 2004 5:36 pm
It sounds like you're losing too much manifold vacuum when you do that. The brake booster requires intake vacuum and with opening the throttle wide open, all of the vacuum is lost and of course the motor runs like crap because the carb isn't running working correctly. You might be wise to go thru the entire motor looking for air leaks. The brake booster might be a leak source.
PostPosted: Sat Dec 11, 2004 1:44 am
:D
I like that one :!: :!:
Lookin for another one.
