It is currently Sun Jun 07, 2026 12:58 am
 Post subject: 4x4 transfercase
PostPosted: Thu Dec 05, 2002 7:13 pm
hey guy's, need a little info. on a 4x4 trasfercase. i was using my 4wd today and it wants to jump out of 4wd hi. any ideals on what causes this and what to check for?
PostPosted: Fri Dec 06, 2002 12:21 am
well i would check the fluid level in the t-case, then i would check the fluid level in your front diferential becouse if its dry it could bind and kick it out.
PostPosted: Fri Dec 06, 2002 12:18 pm
Hey low,
Well my 81 has never wanted to stay in 4hi, Thae shift pattern for the t-case kinda leaves it in a sloppy spot at the top between 2hi and 4lo. My lowbuck solution is a 23mm combo wrench wedged between the stick and the seat. As for the real fix I'm not sure, I think it was just an iffy design from the factory.
Dave
 Post subject: 4X4
PostPosted: Mon Dec 09, 2002 9:35 am
Mine does the same thing. I think it is the stiff shift boot on the stick. The detent spring isnt very strong either. I agree , it is a bad design. Just wedge a stick or wrench there to keep it in gear.
1980 4X4 LUV
PostPosted: Sun Feb 02, 2003 8:24 am
they all do it but u can help it buy fitting a heavier spring 8)
PostPosted: Sun Feb 02, 2003 6:55 pm
Putting a body lift on a LUV makes this problem much worse, especially if you don't do any cutting around the 4WD shifter. The one 4WD LUV I have that has no lift also has no problem staying in 4HI.
PostPosted: Mon Feb 03, 2003 12:49 pm
l was thinking about a body lift but am not sure about the steering box angle. :?
Users browsing this forum: Baidu [Spider] and 32 guests
