It is currently Mon Jun 08, 2026 2:07 am
 Post subject: clutch
PostPosted: Wed Nov 03, 2004 4:23 pm
hey everyone I'm new to this forum and to luv's so I'm looking for some of the wisdom of many you who have had luv's for year's
I have an 81 4wd and the clutch is going out. I'm going to pull the engine and do a couple other mods (weber carb ) but I was wondering what brand clutch would you recommend. I just want something that will last awhile, it has the stock engine( 1.8 isuzu and 4 speed trans). also will those 5 speed trannys from the diesels and the isuzu pups mate up to the stock engine, wouldn't mind having that overdrive.
I can't believe the deal I got for this luv. I paid 225 from the original owner it has 90K original miles and the bodys pretty straight a little dent on the hood and one of the rims isnt mathching but i just couldnt pass it up. My dad has had Luvs in the past and always talked highly of them.
Any help would be greatly appreciated
cruisertay
PostPosted: Wed Nov 03, 2004 6:37 pm
I don't know about clutch brands, mine came with the truck. All I had to do was put it in, (what a pain).
As for the 5-spd. It will bolt right up to the engine, but I've heard you have to manufacture some stuff to make it really work. Including: new shifter hole, new tranny mount, e-brake bracket, and a shortened rear driveline, cause the 5-spd is just a few inches longer. If you're still interested I'm sure someone here can fill you in on more details or point you to a thread, cause believe me, it's been talked about alot.
Welcome to the sight and happy Luvin'
1980 Luv Mikado 4X4
PostPosted: Wed Nov 03, 2004 11:16 pm
centerforce makes a clutch i believe for your truck
performance but be prepared to spend about 200-250 dollars
last a lot longer than a 60 dollar clutch also
i think its worth the money
PostPosted: Wed Nov 03, 2004 11:33 pm
Thanks
More problems though i was out driving it around today and then i just lost power. It's like it was getting no fuel, when i pushed on the gas my rpm didn't rise but i could here the carb sucking. then when I looked at it there seemed to be extra fuel in the carb. I don't no much about carbs but i no that they can be tricky any advice would be appreciated
PostPosted: Thu Nov 04, 2004 8:53 am
The stock carburators on these trucks are painfully troublsesome and complicated. Most people, once they start having carb problems cannot make them go away until they get a new one, and even then there's problems. The direction most people go, as long as they don't have to worry about emissions is to buy a weber carburator.
1980 Luv Mikado 4X4
