It is currently Mon Jun 08, 2026 2:07 am
 Post subject: Grinding problem
PostPosted: Tue Oct 19, 2004 5:07 pm
Hey everybody!!, Im new here and I have a small problem, Whenever I start my truck, it makes a loud grinding noise. My friend thinks that it is the starter, but it is new. My uncle thinks that its the flywheel. This noise is very annoying and very noticeable. Oh, and I have a 1.8 stock, 79 Chevy Luv 4X4. Its my pride and joy. Any input would be appreciated beyond words
PostPosted: Tue Oct 19, 2004 5:15 pm
You might need to shim the starter out a bit...
Welcome to the site :D
Resident lurker
PostPosted: Tue Oct 19, 2004 9:00 pm
Thanks, I will try that, what do you think about the flywheel idea? Could it also be a problem?
PostPosted: Tue Oct 19, 2004 10:12 pm
check the teeth out and make sure they aren't all boogard up. if not i'd say its ok
Resident lurker
PostPosted: Wed Oct 20, 2004 12:39 am
Welcome! :D
Starter shims.
I've had this issue with my fullsize Chevy starter before. Check the flywheel teeth as mentioned already to make sure it's good, but the noise is caused by the starter pinion not being shimmed properly. When the starter pinion moves out all the way it should be lined up with the flywheel perfectly or as close to perfect as you can.
Cement Shoes available here....One size fits all!
"Rum And Pepsi's Got Your Whole Perception Of Me Sketchy.....Cause When I Stage Dive, People Are Scared To Catch Me"
PostPosted: Wed Oct 20, 2004 12:55 am
Yha Yha, what they said!! and WELCOME to the site :D
PostPosted: Sun Oct 24, 2004 9:26 pm
this may sound stupid but what is a starter shim
PostPosted: Sun Oct 24, 2004 10:04 pm
Its a thin metal shim that goes between the starter and the block to help align the starter to the flywheel. P.S the only stupid question is one not asked :D
PostPosted: Thu Nov 04, 2004 9:58 am
Well, I figgured it out. Once again NAPA sold me a shitty part :evil: , the replacement starter that I bought about 3 months ago wasent retracting all the way and it managed to chew up the teeth on my flywheel. Its not that bad though, but I would suggest not to buy your starter from NAPA if you can avoid it.
