It is currently Sun Jun 07, 2026 8:14 pm
 Post subject: Brakes sticking....
PostPosted: Sun Oct 17, 2004 12:31 pm
The first time i hit the brakes after I warm up the truck the brakes lock down with only a slight tapping reacting as though I had stomped the pedal. After a couple of pumps they react normally.
Are my brakes failing?
PostPosted: Sun Oct 17, 2004 4:43 pm
Luvtruck.com Wookie
sounds like your brake booster has a bad rellef valve to me.....
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sun Oct 17, 2004 4:44 pm
i had the same problem, i just flushed the brakes and took out one of the spacers on the disc brake pad, now they work fine.
