It is currently Sun Jun 07, 2026 8:14 pm
 Post subject: Lower Radiator Hose
PostPosted: Thu Sep 23, 2004 10:02 pm
I havent been able to find a new replacment for the lower hose on the radiator for my 80 Luv 4x4. Can you still buy them?
If Not, where would you go to have one fabricated.
I pulled one from a wrecking yard for a $1, it has no holes but I though a shop could use it as a template.
PostPosted: Thu Sep 23, 2004 11:13 pm
Just go get a FLEX hose same diameter and length as what you need.
(Fabricate one.....seriously now :roll: ) It's NOT necessary 8)
PostPosted: Thu Sep 23, 2004 11:20 pm
The lower hose is just an elbow so it should not be a tough one to find. Get the right diameter and cut the ends down to fit. Flex-n-fit hose will work as well. Personally I just like the smooth hose better, but I can't come up with a good reason why a flex hose wont work just as good.
http://www.rockauto.com shows the Gates molded hose as being available and Gates part number 20791. They also have an AC Delco hose part number 22072M for a bit more listed as available but with a shipping delay as its a non-stock item. Any local shop worth a spit can look up either number and cross it with something they have/can get.
PostPosted: Thu Sep 23, 2004 11:26 pm
you should be able to get one. i got one at autozone.
fix it asap. thats why my head blew :x hose blew up and i tried nursing it home (less than a mile) :oops:
 Post subject: Lower radiator hose
PostPosted: Fri Sep 24, 2004 12:15 am
I got one from Schucks a couple years ago. Aren't they affiliated with Pepboys?
 Post subject: flex hose suck
PostPosted: Sun Sep 26, 2004 1:01 pm
I did find a pre-formed hose from NAPA. its less than 10 bucks.
Way better than the Damn flex hoses. The flex house is POS, they dont last as long as the pre-formed.
PostPosted: Sun Sep 26, 2004 6:13 pm
I know I dont have a stock truck but I used those stainless flex hoses and they were great for the tight bends and close spaces
GOTTA GET A NEW LUV!!!!!!!!!
 Post subject: water inlet
PostPosted: Tue Oct 12, 2004 11:07 pm
So I got both new pre-fromed radiator hoses for my Luv.
Also on Napaoline, you can get a replacement for the "Gooseneck"
or the techanical name is the "Water outlet". It's the pice on top of the inatake manifold that has the thermostat just underneath.I think the Water Inlet was only 15 bucks.
