It is currently Sun Jun 07, 2026 6:11 pm
 Post subject: shift boot
PostPosted: Mon Jun 14, 2004 7:30 pm
Is there any place that anyone may know where to get a replacement stick shift boot ? I've tried the junk yards, no luck . I would like to find the original type and not go with aftermarket ones that screw in.Or are there any other trucks that used the sameone?
PostPosted: Mon Jun 14, 2004 10:59 pm
I haven't seen much that is a match, but there might be something out there. There are two styles in LUVs, 77 and older have a small solid steel shaft and 78 or 79 they switched to a stick that is about one inch around that slips down over a shorter shaft. The boots are fairly different between the two at least on the stick end. I know my 86 Isuzu Trooper had a large sized boot and I suspect the 81-up isuzus would be similar to the Trooper and not fit a LUV.
Junk yards are about the only place for an original unless someone here has an extra around. Yards are also probably the best place to go looking for alternatives in other rigs too. Measure the hole in the floor and start climbing in rigs at the yards looking for something that would match.
PostPosted: Tue Jun 15, 2004 6:51 am
Welcome to the site.
What year truck do you have? If I find a boot for you I will ship it to ya my cost plus shipping.
PostPosted: Tue Jun 15, 2004 9:06 am
thanks for any help, my truck is a 79 2wd
PostPosted: Tue Jun 15, 2004 10:06 am
My local Isuzu dealer got one for me a couple of months ago. Cost $30, though.
PostPosted: Tue Jun 15, 2004 12:56 pm
look for mid 80's troopers in the junk yards. The boots are identical for 79-80, even for the 4X4 transfer case boot.
PostPosted: Tue Jun 15, 2004 3:57 pm
Thanks guys that will help alot. I see lots of troopers in the junk yards.
Users browsing this forum: Google [Bot] and 36 guests
