 Post subject: clutch problems
PostPosted: Thu Jun 10, 2004 1:52 am
alright so whenever im slowing down from freeway speeds and downshifting with each gear i feel the stick shaking. it feels sloppy and alot of vibration. so this means its time to replace the clutch right?
PostPosted: Thu Jun 10, 2004 3:04 am
It may be a bad and/or loose transmission/motor mount also.
77 2wd - Back on the road
05 Ford Five Hundred
PostPosted: Fri Jun 11, 2004 1:28 am
thanks i'll check the mounts. i dont want to be a post whore and start a new thread. but i need to change my brakes this weekend also. so i have the rear shoes and know i need to pick up the front ones. now ive been driving on bad brakes for awhile now. : ( so how do i know if my rotors are still good or not? and is this somethin' a machine shop can fix if their messed up? and when you guys do your brakes what all do you look for while changing to see if anything else with the system needs to be replaced? thanks
PostPosted: Fri Jun 11, 2004 10:11 am
Just check for worn or damaged parts, replace what you need to. Check the brake lines while your at it too. As for the drums and rotors, unless they look perfect, take them to a shop, they can check the drums for out of round, taper and wear. the discs need to be checked for flatness, that the sufaces are parallel to each other, check for runout and thickness. You can check all this yourself, but you need the tools and a manual would help.
Resident lurker
PostPosted: Fri Jun 11, 2004 12:11 pm
if the clutch is going out, the engine will usually rev higher than it should on heavy acceleration
try dumping it in 3rd gear from a dead stop, if it lugs out the engine badly it's usually good, if it kinda slips in and goes you probably need a new one
PostPosted: Sat Jun 12, 2004 5:27 am
alright well this weekend will be eventfull. i have my plate full with some dump runs then brake job. and a questionable clutch. but hey....thats what weekends are for. and im looking forward to every minute of it. i have a haynes or is it a chilton book....never paid much attention to the title. pretty sure its a haynes. anyways it covers a mass number of years.....79 being one of them. is there a more detailed manual i can get direct from the factory which is specific to my 79?
PostPosted: Sat Jun 12, 2004 7:17 am
you can find the shop manuals on ebay pretty cheap. I got mine for like 5 bucks.
Resident lurker
PostPosted: Sat Jun 12, 2004 9:26 am
youll be bale to see scars and such on the rotors. If the look and feel flat then your probly good. Local parts stores can usually turn em for you, for not too much money. As far as your shaking problem, check out the motor mounts and such. I wasnt having this exact problem but i tore my driver side motor mount clean in two and the bell housing was hitting the body work. :oops:
