It is currently Sun Jun 07, 2026 8:05 am
PostPosted: Wed May 05, 2004 6:55 pm
Luvtruck.com Wookie
i wa slooking at the eletronic ign. conversion from pertronix and noticed that the catalog only mentions 74-75 luv....
they still work in an 80 don't they?
would hate to buy something that don't work......
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed May 05, 2004 10:12 pm
I called them long distance before I sprung for my Mallory Unilite for my 80 LUV. They said no but if I wanted to send them the distributor, they would engineer and make one for me. Might take a few weeks, tho.
PostPosted: Thu May 06, 2004 1:50 am
i bet that'd cost alot 8O
PostPosted: Thu May 06, 2004 10:38 am
As I remember, the cost wasn't too great. I was turned off by the down time I couldn't drive my LUV. I had a Petronix in my 72 F250, and it was working great 20 years later when I sold the truck.
PostPosted: Fri May 07, 2004 8:23 am
I have 3 Pertronix in My Dtasuns and installed one on a Jeep and a Corvette.
I know for my Datsuns I had to have a single point Hitachi distributor.68-69 70-73 will not fit So if a 68-69 contact set for a 510 is the same as a luv for that year it will work. So go to the parts store and compare the 2. If not forget it
It will not fit the dual point distributors.
If you have a dual point(as in the 510s) it will not work.
They just mount where the screws hold down the points.
Cheap system that works great if it fits your vehicle.
I personally dont like the Mallory Unilites. I hear of to many failures.
PostPosted: Fri May 07, 2004 10:17 am
Now you tell me. :(
PostPosted: Fri May 07, 2004 12:57 pm
Luvtruck.com Wookie
so where to i find a cheap(under$100) elec. ign. set for my luv? I've heard bad thing about the malory too.
the sets that i've seen are relativly not too expensive but you need an expencive coil to go with it
i'm consitering a switch out from a isusu truck,but i don't know what years are compatible
TiLtEd wrote:
Boobies!!! :D
PostPosted: Fri May 07, 2004 3:40 pm
The part number of the 80 LUV and 81 LUV are almost identical. The last number is the difference. It's solid state ignition and I would think work.
PostPosted: Fri May 07, 2004 3:49 pm
http://www.partsamerica.com/SelectParts ... istributor
Go to partsamerica and enter your yr vehicle . Go to disributor and it will show the difference(photo). It shows electric for the later yrs
The 74-75 looks like a Datsun 510 distributor with a different bottom tang installed. Thats it.
PostPosted: Sat May 08, 2004 10:55 pm
I went with Crane Cams XR3000 for mine, and I love it. They support the Nippondenso distributers that came in the later LUVs, so its basically an out-of-the-box conversion. Doesn't take too much time and cost me $100. I definately recommend it.
Users browsing this forum: Baidu [Spider] and 20 guests
