It is currently Sun Jun 07, 2026 7:12 pm
PostPosted: Fri May 21, 2004 5:32 pm
On a 80 Luv 4x4
I'm going to replace the master cylinder, just wanted to know any tips on this before I take on the task. So far I have heard someitmes you have to
bleed it by opening the brakeline that screw in the side. I'm also getting a decent flare nut wrench for the brakelines. I had a Kragen's brand, it sucks and the wrench end flexs.
PostPosted: Fri May 21, 2004 8:08 pm
Luvtruck.com Wookie
do you know how to bleed a master cylinder? get the kit from whoever you got that wrench from it'll save you a hell of a headache
TiLtEd wrote:
Boobies!!! :D
PostPosted: Sat May 22, 2004 3:33 pm
I didn't have much trouble when I did mine, but you can bench bleed it before you put it on. If not you may be pumping a long time to get the air out of everything pushing it through the wheel cylinders. Usually the replacement master cylinder will come with a set of instructions for bench bleeding it. I think it boils down to just clear out all the old fluid in the system and all the air in the lines when you are done. The rest is just bolting stuff on. After you are done, expect to spend a lot of time cleaning up brake fluid on the inner fender and frame right below there. If you get any on paint you want to keep, clean it off right away. That stuff strips paint quite fast.
Users browsing this forum: Bing [Bot] and 44 guests
