It is currently Sun Jun 07, 2026 2:25 pm
PostPosted: Tue Apr 27, 2004 3:04 pm
My right front torsion bar is snapped mostly inside the crossmember. How does one go about removing the torsion bar?
Thank you in advance,
Dan Smith
PostPosted: Wed Apr 28, 2004 4:55 am
there is a nut on the front of the torsion bar.
you should be able to remove it from the front.
or do like I did....use a torch. :D
03Cobra
PostPosted: Wed Apr 28, 2004 10:27 am
The torsion bar does not disconnect in the rear, but slides out of the splines? Thanks.
Dan
PostPosted: Wed Apr 28, 2004 10:35 am
yeah, mine had a splined end that went into the lower control arm, the opposite end was the lever system and it just unbolted as far as I can remember.
I TOOK UR MOM DRAGGIN LAST NIGHT
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Fri Apr 30, 2004 12:50 am
just cut sick at it, undo any bolts attached to it, there isnt many
