It is currently Sun Jun 07, 2026 8:04 am
PostPosted: Tue Apr 27, 2004 10:35 am
I have a used windshiled i scored at a u-pull-it this weekend. The windshield in the truck now is cracked real bad. I pulled the windshield out this weekend and scrapped it. I need a new gasket, but aside from that are there any tricks to installing them other than using a small diameter rope and walking it in? I read an how to on the internet and its seemed pretty easy but I am affraid of cracking this replacement windshield....
is this something you would attempt or would you have somebody do it....I'm kinda on the fence here...
I TOOK UR MOM DRAGGIN LAST NIGHT
Bagged 84 Pup
Bagged 53 F100
stock 72 Citroen DS19
PostPosted: Tue Apr 27, 2004 11:44 am
Fit the gasket to the glass, then put the rope in the gasket groove, then set it in the truck's groove, setting the bottom of the glass first. You will want to arrange your rope so that it will pull out from the bottom to the top. I think the way we did it, we pulled the rope from the inside of the truck, but I cant remember for sure. You will know which way to do it once you get the gasket on the glass. You will be able to tell that it will pull easier one way than the other. Use something to lubricate it in that will dry later, like Windex or some other glass cleaner. You can (and will need to) push along the edge to seat in better into the gasket as you are working (i.e. push on the top edge to seat in the bottom of the gasket better), but no matter how tempting dont push ON the glass too much (push gently if at all), especially if it is getting into a bind. Otherwise, you will do like I did the first time, and almost have the windshield all the way in and it was bowing a bit, and I pushed a bit with the palm of my hand and it cracked. Just back it out and start over again. Most important rule is to be patient. I had a pro come out and do my second attempt and this is what he did. Even he had to start over once, but after it was all said and done, it only took like 30 minutes.
PostPosted: Tue Apr 27, 2004 12:19 pm
do you remember what diameter rope I should use.....3/16" smaller?
a friend at work told me the exact same thing you said so i feel better now. I just need to go out now and buy a gasket for this thing...
Bagged 84 Pup
Bagged 53 F100
PostPosted: Thu Apr 29, 2004 3:48 pm
3/16' diameter will probably be just right.
PostPosted: Thu Apr 29, 2004 7:32 pm
SunDown,
Check out this website it has a pretty good pictoral on the windshield replacement
http://www.route66restorations.com/1.html
PostPosted: Fri Apr 30, 2004 10:33 am
awesome, thanks for the link Kaneguy!
Bagged 84 Pup
Bagged 53 F100
PostPosted: Fri Apr 30, 2004 2:37 pm
Anytime.... let me know how it goes, I'm going to install one after I get the truck painted.
PostPosted: Mon May 03, 2004 11:54 am
yeah, thats where I'm at too. I have the old windshield out but I'm not going to install the new used one until I at least have some dp90 down...I'll let you know how it goes.
Jason
Bagged 84 Pup
Bagged 53 F100
Users browsing this forum: Baidu [Spider] and 22 guests
