It is currently Sun Jun 07, 2026 8:05 am
PostPosted: Wed Apr 21, 2004 8:38 pm
My new 72 2wd is an undesired low rider.
The lower A-arm is setting up against the frame.
What does this sound like?
Thank you,
Dan Smith
PostPosted: Wed Apr 21, 2004 8:50 pm
First thing you might want to look at is the torsion bar adjustment. At the transmission crossmember you'll find an adjustment bolt at each of the ends of the torsion bars. If there's a lot of threads between the bolt head and the adjuster, the bars are relaxed enough to make the front end sit low. If this is the case, Jack the front end of the truck and tighten the adjustment bolts equally(about a 1/4" inch at a time) until you have the ride height you want or need.
Users browsing this forum: Baidu [Spider] and 20 guests
