It is currently Sun Jun 07, 2026 1:37 pm
PostPosted: Tue Mar 30, 2004 7:02 pm
I'm replacing the front brake hoses on my 80 luv. I am hoping someone else has done this before so it will they will be familar and give me some help.
The connection where the hoses bolt to Calipers have a pin besides the hole for the bolt. I tried starting the bolt and then trying to put the pin after. Doesnt work. The pin is about 1/8 off the hole. I compared the new hoses to the orignal and they are the same. Previous work I put rebuilt calipers on, but dont remember the pin. The pin isnt used for the fulid just to help align the fitting. All I can come up with is to face the pin outward and not bother using it. Any Suggestions?
PostPosted: Tue Mar 30, 2004 10:39 pm
i had that same problem, i just ligned it up as close to the hole as i could, and started tightening the bolt and it pushed the pin out. when the bolt was tight, i took a hammer and drove the pin into the hole.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
 Post subject: pin and hammer
PostPosted: Tue Mar 30, 2004 11:08 pm
Just to get the process in the right order. You first had the pin facing inward. It pushed the pin out. THen you tapped in back in with a hammer.
As long as I am not too heavy handed it sounds like the pin can be tapped into place.
PostPosted: Wed Mar 31, 2004 10:54 pm
yep thats what i did
 Post subject: modifcation
PostPosted: Wed Mar 31, 2004 11:56 pm
I ended up making the hole for the pin a little bit bigger. Its 1/4 inch so
I went to 9/32 and then taped the pin in. Another note: The new hoses did not have a clip on the middle section. So I bought 9/16 E-rings and put them on where the old ones were. This would keep the hose sliding away from the bracket.
