It is currently Sun Jun 07, 2026 8:22 pm
PostPosted: Sun Mar 28, 2004 10:04 pm
Will a 79 alt. work in a 72 truck? They seem to have the same connector and + & - post setup.
PostPosted: Sun Mar 28, 2004 11:49 pm
If the pulley lines up, it should work fine.
PostPosted: Mon Mar 29, 2004 5:46 pm
I dotn see why not... i switche dmy ole engine over to a delco alt... used stock brackets, then I put an 86 nissan alt on
PostPosted: Mon Mar 29, 2004 11:28 pm
Shoure does. I have a 73 and a 75 and the Alt's are the same. The starters are a bit different since the 73's is on the drivers side and the 75's is on the passenger side.
