It is currently Sun Jun 07, 2026 8:21 pm
 Post subject: leaking clutch
PostPosted: Sun Mar 21, 2004 8:50 pm
Anybody have or had problems with the clutch fluid reservoir leaking into the cab? Mine leaks from the ram in the firewall. I really don't want to replace it. Any suggestions?
PostPosted: Sun Mar 21, 2004 9:04 pm
if its leaking down the fire wall your master cylinder is going out. I dont think its teribly hard to change out.
 Post subject: cake!
PostPosted: Sun Mar 21, 2004 9:26 pm
dude it easy as hell to replace! i changed my luv over from a auto-magic to a manual and it was cake! took mabye 30 min in all to put in the mater and slave cylinder and plumb it!
PostPosted: Mon Mar 22, 2004 11:38 pm
It is easy to replace, and really quite easy to rebuild with the kit as well. The hardest part is getting the system bled again after reassembling it. If you have fluid coming in the cab, then the master cylinder needs replaced or fixed. There is no way around it, just a matter of time before you suck air into the line and the clutch no longer disengages. I drove my 76 every day for a week without using the clutch the last time I had that problem.
Users browsing this forum: No registered users and 53 guests
