 Post subject: Transfer case
PostPosted: Tue Mar 16, 2004 11:46 pm
I'm underneath hooking the clutch cable back up and see that the output from the transfer case is leaking. The skid plate is soaked also. I just changed that output shaft seal 3 or 4 years ago. The front drive shaft slip spline is a little loose, and I'm wondering if the wobble from that could cause the seal to start leaking. Anybody else have this happen? If so, I might as well get the drive shaft rebuilt and change the seal while the truck is up on jack stands. I never had this problem on my old F250.
