It is currently Sun Jun 07, 2026 4:58 pm
 Post subject: tires
PostPosted: Thu Mar 18, 2004 9:10 pm
Does anyone know if i could run 30x9.50 on my luv with 15x8 or 7 wheels
or if not how much trimming would i have to do i have 2'' torsion bar lift and shackle thanks. 8)
PostPosted: Fri Mar 19, 2004 12:00 am
i'm pretty sure they will rub in the front, you could add a body lift, jc whitney sells them in 2" or 3" for about $80. or you could trim the outer lower corner of the fenders and probably the inner fender well, to keep them from rubbing when you turn.
1980 chevy luv 4x4 1.8 liter
1979 luv long bed parts truck
