It is currently Sun Jun 07, 2026 4:58 pm
 Post subject: it actually works
PostPosted: Fri Mar 05, 2004 7:07 pm
well, my luv runs. it was a sloppy bitch to work on , but after pulling the motor and changing the timing chain that bitch fired right up. not bad for $100. i had to go with the old chain and bolt trick because one of my motor mounts was missing the studs. hope it holds
PostPosted: Sun Mar 07, 2004 1:04 am
i juat got mine running too. how did that head work out for you?
PostPosted: Mon Mar 15, 2004 9:02 pm
the head was crack free. for some reason my truck smokes so i havent been driving it around. it ended up costing about $200 to get the valves reground and the head shaved
PostPosted: Tue Mar 16, 2004 8:33 am
Im glad I go to a vocational school, got both my 3.8 heads, shaved, port and poslished, 3 angle valve job for 30 bucks. Why didnt you jsut buy a new motor mount, they ar elike 8 bucks a piece, at autozone
