It is currently Sun Jun 07, 2026 10:41 pm
 Post subject: stock 79 LUV specs...
PostPosted: Mon Mar 08, 2004 10:53 am
hey. i would like to know what the HP, torque, 4 spd. gear ratios and rear end gears are on my truck. stock 1.8L with 2BBl carb and a 4 spd tranny.
thanks!
PostPosted: Mon Mar 08, 2004 5:31 pm
power, 85hp@4800rpm Troque, 95ft-lb@4000rpm(?)
Gear ratios, Reverse:3.83:1
1st: 3.79:1
2nd: 2.18:1
3rd: 1.42:1
4th: 1.00:1
Transfer case
high range: 1.00:1
Low range: 1.87:1
Hope that helps!
 Post subject: truck specs
PostPosted: Mon Mar 08, 2004 8:34 pm
It depends on the truck as far as hp and torque goes
PostPosted: Tue Mar 09, 2004 12:54 am
those are the factory specs for a 78-80. Before that it was 10hp and 10ft-lb lower. I dont know about 81-82.
PostPosted: Tue Mar 09, 2004 11:04 am
thanks! looks like im gonna be doin a motor swap....
Users browsing this forum: Baidu [Spider] and 28 guests
